Show your 33's
#4061
I have not disconnected the sway bars yet but at full articulation I have no problems. I didn't mention that I have a 2" AEV spacer lift. The question seemed to be asking about needing wheel spacers or not. A response was that rubbing on the sway bar was happening. I have not had this issue. At least with the steering stop spacers.
#4062
So I'm currently running 1.5" Spidertrax wheel adapters on stock wheels and tires on my 2015 JKU Sahara. I'll be installing a TF 1.5 spacer leveling kit in the near future. I plan on purchasing 33s for my 18" stock rims shortly after that. Any suggestions on some good 33s (specific sizes and brands) that will not rub given the set-up I just described? Many thanks!
Cheers,
DJ
Cheers,
DJ
#4064
So I'm currently running 1.5" Spidertrax wheel adapters on stock wheels and tires on my 2015 JKU Sahara. I'll be installing a TF 1.5 spacer leveling kit in the near future. I plan on purchasing 33s for my 18" stock rims shortly after that. Any suggestions on some good 33s (specific sizes and brands) that will not rub given the set-up I just described? Many thanks! Cheers, DJ
#4068
Just put new 305/55/20 Mickey Thompson Baja ATZ P3 on 20x10 Black Rhino Sierra Wheels. Then added the Teraflex 1.5 in. leveling kit and removed the brown Sahara stickers to finish it off. Very happy with how this turned out. I know some hate on the 20's, but I love these. Glad I didn't go smaller. Tire spec is 33.5 inches, and they ended up at 32.75 under load. Used the Procal to calibrate the speedo, and gas mileage looks to be in the 16.5 range (was about 18 prior on stock wheels/tires
