Show your 33's
#3493
33's will fit just fine on a stock JK, but depending on the width of the tire you may require some tweaking. If you are buying these to put on your jeep rims then they may rub depending on the size. Getting new rims and or wheel spacers will prevent that. I recently upgraded to 33's, 285/70/17 and they did fit on my factory wheels without issues, but rubbed with tight turns. Spidertrax wheel spacers solved that. For two weeks I drove my jeep without recalibrating for the new size. Speedometer was slightly off as were my shift points (I drive automatic) so it had a bit of hard time shifting gears when I wanted it to. After the recalibration was fine, I lost about 2mpg on average.
#3494
#3495
I used the AEV procal. Simple and easy and not too costly. It only took a few minutes too and now my shifting is on point
