Sponsored by:
Sponsored by:
Show your 33's
Old 05-04-2014, 01:58 PM
  #3481
aldaman's Avatar
Originally Posted by Pats fan
what setup do you like better?
Originally Posted by Sahara_Steve
I'm curious too which you prefer with bigger tires??? You had any flex issues with the 35's hitting fenders?
I have a 2.5" on 33's and feel it somewhat makes tires looks small. From a far at least, but close up seems alright
I like the 35" set up right now. Aesthetically it matches the unlimiteds better IMO. No flex issues thus far. My bump stops do a good job preventing any rubbing of the fenders...
Old 05-04-2014, 02:30 PM
  #3482
PBone's Avatar
Originally Posted by Westbayou
295/70/17 Trail Grapplers, 1.5" Rough Country wheel spacers, Teraflex leveling kit.
Attachment 549752
That is perfect!
Old 05-04-2014, 02:58 PM
  #3483
jjmmagoo's Avatar
Thinking sometime this summer depending on the funds of getting 33's on my unlimited x. I have heard that you do not need a lift to accommodate this setup. IF I was to consider a lift what's the minimum size lift that I would need to accommodate 35's?
I think I am going to stay with the idea of 33's. I don't plan on doing a ton of off-roading maybe some camping and beach driving. Also if I do go with 33's do I need to recalibrate my speedometer and will I see a huge difference in mpg's? Thanks for all your guidance.
Old 05-04-2014, 04:42 PM
  #3484
spiderball32's Avatar
Got my 2.5 in lift and tires on over the weekend.
Old 05-04-2014, 06:11 PM
  #3485
roadside_doc's Avatar
Default lift
did you put spacers on the back too or just 2' on front
Originally Posted by djVb
Here are my 33x12.50 on 20x10 Fuel Mavericks with 2 in level kit.
Old 05-04-2014, 08:07 PM
  #3486
blindman99's Avatar
Love my 09 jk Sahara unlimited
Old 05-04-2014, 08:46 PM
  #3487
LoneWolf's Avatar
Originally Posted by spiderball32
Got my 2.5 in lift and tires on over the weekend. Sent from my iPhone using Tapatalk
Looks great. What setup are you running?
Sent via Jeep wave from my NSA-approved domestic espionage device
Old 05-04-2014, 08:58 PM
  #3488
2.5 in skyjacker suspension lift. 33x12.50 r15 Goodyear mtrs.
Old 05-05-2014, 05:33 AM
  #3489
Sahara_Steve's Avatar
33's will fit just fine on a stock JK, but depending on the width of the tire you may require some tweaking. If you are buying these to put on your jeep rims then they may rub depending on the size. Getting new rims and or wheel spacers will prevent that.
I recently upgraded to 33's, 285/70/17 and they did fit on my factory wheels without issues, but rubbed with tight turns. Spidertrax wheel spacers solved that. For two weeks I drove my jeep without recalibrating for the new size. Speedometer was slightly off as were my shift points (I drive automatic) so it had a bit of hard time shifting gears when I wanted it to. After the recalibration was fine, I lost about 2mpg on average.
Old 05-05-2014, 06:13 AM
  #3490
jjmmagoo's Avatar
33's will fit just fine on a stock JK, but depending on the width of the tire you may require some tweaking. If you are buying these to put on your jeep rims then they may rub depending on the size. Getting new rims and or wheel spacers will prevent that. I recently upgraded to 33's, 285/70/17 and they did fit on my factory wheels without issues, but rubbed with tight turns. Spidertrax wheel spacers solved that. For two weeks I drove my jeep without recalibrating for the new size. Speedometer was slightly off as were my shift points (I drive automatic) so it had a bit of hard time shifting gears when I wanted it to. After the recalibration was fine, I lost about 2mpg on average.
Awesome information! I was trying to stay with the original rims. I take I would only need spacers in the front?
Quick Reply: Show your 33's
