Sponsored by:
Sponsored by:
Show your 33's
Old 02-05-2014, 07:11 AM
  #3281
Lucifer's Avatar
Originally Posted by FrenchJK
nice ride, how about removing the bench in front of your JK? 285's or 33's? (basically the same with cooper)
285's, and yes, a nice bumper would look great so I'm thinking of replacing it .
One of the bumpers I really like is the Warn elite.
Old 02-05-2014, 07:28 AM
  #3282
BlackRockBurner's Avatar
Originally Posted by Chemops
Ok, after a few days of reading I have yet to find out definitively if anyone has tried to run 305/60r18 km2's on a stock 2010 unlimited sahara with stock rims WITHOUT a leveler or spacers... Some say NO PROBLEM, others say definitely rubs.... So confused
When I ran 275x70x18's and no other mods, I rubbed the front lower control arms during full turns. I adjusted the steer stops so it would not rub. So, with over an inch wider tire, I'm sure you will rub too. You can add 1.5" wheel spacers to solve this issue.
Old 02-05-2014, 09:22 AM
  #3283
Stephane87's Avatar
My friend put the same size as you on a Sahara with Sahara wheels and he had to put Spidertrax 1.5" wheel spacers because there was rubbing. He also have a AEV 2.5" lift.
Old 02-05-2014, 09:28 AM
  #3284
Stephane87's Avatar
I plan to upgrade as far as I can go with the platform I have and eventually give it to the wife so I can get a different year but times are hard so I'm trying to get by with tires first and a leveling kit later. Why does the teraflex 1.5" have different spacing front and rear. I'm getting amped to learn as much as I can Jeepin can be addicting
The front of a JK or JK Unlimited is usually between 3/4" to 1" lower then the back, so the TF leveling kit come with 2 front puck (1" each) that you can put on top of each other, and 1 back puck (1"). If you want to level the Jeep then you put 2 in front and 1 on the back. Also, if you have a heavy front bumper or winch...for sure you will put the 2 puck in the front to compensate for the extra from weight...
Old 02-05-2014, 10:48 AM
  #3285
jeepblackout's Avatar
I wouldn't try with stock wheels without wheel spaces. Having some kind of offset always helps. I run 305/50/20s with Raceline octane they have a 5in backspace. The spacing helps.
Old 02-05-2014, 12:04 PM
  #3286
Chemops's Avatar
Ok, so as I understand it.... A 2010 unlimited sahara can run 306/60/18 km2's on stock 18" wheels with just 1.5" spacers. Will I need the teraflex 1.5" leveling kit to ensure enough height?
Old 02-05-2014, 12:39 PM
  #3287
Stock jeeps can fit a 33" tire. So you don't have to lift for 33's. The wider the tire, the further out ( less backspace) the wheels should sit. If you don't adjust backspace, and adjust steer stops, you will not turn as tight.
Old 02-05-2014, 01:44 PM
  #3288
Chemops's Avatar
OK so just need 1.5" spacers to eliminate rub? Really the only question I have....
Old 02-05-2014, 02:55 PM
  #3289
Correct. For the 305x60x18 (32.4") tires you want.
Now, on with more 33's please.
Old 02-05-2014, 03:36 PM
  #3290
Chemops's Avatar
THERE IT IS!!!!! AWESOME! I'll have mine posted in a few weeks. Thanks blackrock!
Quick Reply: Show your 33's
