Show your 33's
#3281
#3282
When I ran 275x70x18's and no other mods, I rubbed the front lower control arms during full turns. I adjusted the steer stops so it would not rub. So, with over an inch wider tire, I'm sure you will rub too. You can add 1.5" wheel spacers to solve this issue.
#3283
My friend put the same size as you on a Sahara with Sahara wheels and he had to put Spidertrax 1.5" wheel spacers because there was rubbing. He also have a AEV 2.5" lift.
#3284
I plan to upgrade as far as I can go with the platform I have and eventually give it to the wife so I can get a different year but times are hard so I'm trying to get by with tires first and a leveling kit later. Why does the teraflex 1.5" have different spacing front and rear. I'm getting amped to learn as much as I can Jeepin can be addicting
#3285
I wouldn't try with stock wheels without wheel spaces. Having some kind of offset always helps. I run 305/50/20s with Raceline octane they have a 5in backspace. The spacing helps.
#3286
Ok, so as I understand it.... A 2010 unlimited sahara can run 306/60/18 km2's on stock 18" wheels with just 1.5" spacers. Will I need the teraflex 1.5" leveling kit to ensure enough height?
#3287
Stock jeeps can fit a 33" tire. So you don't have to lift for 33's. The wider the tire, the further out ( less backspace) the wheels should sit. If you don't adjust backspace, and adjust steer stops, you will not turn as tight.
#3288
OK so just need 1.5" spacers to eliminate rub? Really the only question I have....
#3289
