Show your 33's
#3071
trying to parse through this
I have a stock - JKU Sahara (sock but i have a set of Moab 17' which would be used with the below tire)
will BFG 285/70R17 KO's fit with no modifications (black sidewall - http://www.tirerack.com/tires/tires....KOV2&tab=Specs )
i want to stay with BFG KO's (been great on my defender....)
#3073
Rlynch356- you could get away with no wheel spacers but 1.5" spacers would make it better. Without spacers you will have to adjust your steer stops by placing a washer or two that limits your turning radius. And at full flex without spacers you may rub.
#3075
Thanks! Not really sure what they (the dealership did the work) used. They did such a great job on my husbands pickup bed, that we went to them for the work - and everything that I wanted them to do, turned out less than whet the Bushwacker set of flares were going to cost - Flares, Grille, Side steps, rub rails, and body between the new bumpers that was covered by the factory bumpers were all covered - the total for all of it was $500 bucks,,,,set of bushwackers,,,,over 750. So I'm REALLY happy with the way the whole job turned out. Plus,,it looks awesome up close!
#3076
