Sponsored by:
Sponsored by:
Show your 33's
Old 06-01-2013, 09:01 AM
  #2981
Stuka's Avatar
Originally Posted by JK Inspired
Need to start a "SHOW YOUR 32s" thread.
When it comes to standard sized tires (33x12.50 for instance) not a single one of them is 33" tall. Almost all of them are 32.5" tall advertised height. With load they are closer to 31.5".
For metric tires, they are almost always over. Cooper and Goodyear for instance are 33.1" tall advertised height for their 285/75R16's.
Old 06-01-2013, 02:12 PM
  #2982
Crimsoncole's Avatar
Originally Posted by GoingGreen
2013 JKU
33v12.50x15 Duratracs
15" MB TKO Wheels
Any lift on this?
Old 06-01-2013, 06:43 PM
  #2983
Halas's Avatar
That is an ignorant statement
I see we have a new expert on the block.
Old 06-01-2013, 06:51 PM
  #2984
Okie Josh's Avatar
Trail grapplers and a tf 2.5 coil lift
Old 06-01-2013, 07:24 PM
  #2985
Halas's Avatar
Sorry, the better word may be troll.
Mt 285/70/17 is 33 - 33.1
At is 32.6 - 32.7
Of course when you lay a ton or so on a d rated tire it may have a flat spot which will cause the top to bottom height to be 32.5 but the front to back would still measure 33.
33 x 12.5 Tires like coopers say that they are 32.5 so you know what you are getting.
285/70/17 bfg mt are stated at 33. I measured true size, after I put a ton on them i am sure that they may have a flat spot causing them to be 32.5 from ground up but still 33 front to back.
Old 06-05-2013, 12:40 AM
  #2986
JK Inspired's Avatar
It's simple math. Metric conversions table are out there for those that don't have those math skills. I'm not referring to ACTUAL height- too many variables.
Old 06-05-2013, 12:42 AM
  #2987
At is 32.6 - 32.7
285/70/17 ANYTHING is 32.7x11.2. It's called mathematics.
Old 06-05-2013, 05:42 AM
  #2988
Teebo's Avatar
Order my Goodyear MTR's with Kevlar this week. They are 285/70 r18 does that count?
Curious how they will look after the 255/70 r18's on their now.
Old 06-05-2013, 05:54 AM
  #2989
Stuka's Avatar
*sigh*
How about you go look at the manufacturers websites for once? Not all tires are the same. Sizes are guidelines and thats it.
This is straight from Goodyears website for their Wrangler Duratrac:
LT285/75R16 312035142 P 126 E BSL n/a 3,750 80 7.5 - 9.0 8.00 11.3 18 33.1 637 $263
LT285/70R17 312015027 Q 121 D OWL n/a 3,195 65 7.5 - 9.0 8.50 11.5 18 33.0 638 $303
See that 33.1 down towards the end for the 16" wheel version, thats the actual tire diameter. The 17" wheel version is slightly smaller, but still not 32.7. Not sure where you got off thinking every tire manufacturer has to make a tire to the EXACT size that is listed on the side. Hell, BFG is known for making tires undersized while goodyear makes them oversized (In many cases, specifically 35's).
Old 06-05-2013, 08:18 AM
  #2990
klankster's Avatar
Too bad even 33's, once mounted to rim and on vehicle are usually sitting at 32 and some change.
Quick Reply: Show your 33's
