Newbie question on tires/wheels
Hey guys and gals, I'm pretty new to all of this and I have a couple of questions. I'm finally adding some stuff to the jeep after 3 years of owning. I started off with Bushwacker flat fenders, also installed a barricade bullbar on it. Next up I'm planning on installing the teraflex 1.5 in spacer kit with 35-1250R17LT Cooper Discoverer STTs and some (17x9"/5x127mm, -12mm offset) XD addicts. MY question is, will I have any rubbing with this setup? Rest of the jeep is completely stock. Will I need some wheel spacers? If so, what kind of spacers do you guys recommend? Any tips or helpful information will be very much appreciated. Look forward to learning more about all of this.
That is about a 4.5" backspace? You should be fine with clearance on the frame/links/etc. But, you will still want to check clearance on the pinch seams/bumpers/rails when stuffed, 'just in case'.
