Largest Tires on Stock 2 Door Rubicon with AEV Wheels
Old 10-12-2015 | 09:37 PM
SunDevils259's Avatar
Originally Posted by BlackRockBurner
OP- all choices are 33's so all will fit. The 255's with no rub while the wider 285's may rub at full lock on control arms. Easily corrected by adjusting steer stops.
Don't want to lessen the steering radius, that's one of the things I love most about the Jeep. It gets me out of most situations I get myself into.
Old 10-12-2015 | 09:47 PM
Originally Posted by CharlieInTheTree
I have 285/75/17 Duratracs on AEV Pintlers. At full turn there is not rub on pavement. Any bumps and full turn, it rubs pretty good. Getting the 2.5 AEV lift next
I don't see that size Duratrac on Goodyear's website. Did you mean 285/70/17?
Old 10-12-2015 | 09:51 PM
Originally Posted by nthinuf
What is listed in the specs can be very different than what you find when you actually pull out the tape measure. Given the same stated size, both height and width can vary quite a bit between mfg's, and even between different tires from the same mfg.
Just one of the reasons you are not going to find a 'clear cut answer'. Others might be fender choice, actual lift height (which could be which of the dozen different stock coils came on your particular jeep vs what the next guy has), how much extra weight is bolted/welded on, how centered you axles are, whether you disconnect, etc, etc, etc ...
Yeah sounds like the only way to fit a bigger tire than stock, and know for sure there won't be any problems, is to lift it. Was hoping to keep it stock but put a little taller tire on. Thanks
Old 10-14-2015 | 03:30 PM
jadmt's Avatar
JK-Forum Ambassador
I installed a 2" aev lift on my buddies new rubicon and then slapped my wheels on it so he could see how it looked with 285/75-17 toyos and pintlers. he did not want to take them back off and talked me into selling them to him.
Old 10-15-2015 | 09:39 AM
See now that looks perfect. Saw a 2 door with 35's the other day and tires look a little big for me. I think those 34's look great. That the AEV 2" spacer lift? Would you be able to send a picture straight down the line of the flares to see how far they stick out? Thanks
Old 10-15-2015 | 10:45 AM
jadmt's Avatar
JK-Forum Ambassador
that is the aev 2" spacer lift. I just installed the lift for a friend and that is the only photo I have. I can tell you that the tires are about even with the flares. They do not stick out.
Old 10-15-2015 | 10:49 AM
mdash's Avatar
That is awesome! Go that guy!
Old 10-15-2015 | 02:24 PM
Perfect, that's the look I'm going for. Thanks for sharing.
Old 10-16-2015 | 10:20 AM
Mud Pilot's Avatar
I am currently running 37"s with beadlocks and no lift. But I am also running Bushwackers Flat Flairs. lol . looks like a beast. and if the pictures messes up then I am sorry, first time poster with pictures. haha
Old 10-24-2015 | 02:07 PM
Fallon3's Avatar
Default Taller tires on stock rubicon?
Originally Posted by SunDevils259
Know many forms of this question are asked, but there never seems to be a clear cut answer on the biggest tire you can run on a stock Rubicon. Asked around many of the local shops as well and get different answers.
I have a 2013 2-door Rubicon with AEV wheels (Backspacing 5.2", Offset +10mm). Can I run BFG Mud KM2 285/70R17 (33" x 11.5") or 255/80R17 (33.3" x 10") or 285/75R17 (33.9" x 11.3") without any issues of tires rubbing on any part of the vehicle while at it's full capability offroad?
Thanks, I appreciate any feedback.
I would like taller mud tires on my stock rubicon but not wider?sorry this is my first post
