2017 JKU wheel/Tire help.
I just purchased a 2017 JKU Sport. I was looking into getting this set up 17x9 Black Level 8 Strike 5's 4.53 BS , 5x5 -12mm mounted / balanced on LT285/70R17 Toyo Open Country A/T II's would this set up work with no lift? I will be getting a Terra Flex leveling kit but wanted to order the wheel package first. Thanks for the help. I had a 2011 JK a few years back but been out of the game a few years.
Nothing in the suspension has changed. They'll fit and under articulation you'll scrub your fender flares.
Cut the flares or add bump stops (lose travel), but cycling as mentioned above would be best bet. Is this a street rig or rock crawler? Should still be ok unless u plan to rock ur jeep hard. Guessing by mentioning a spacer lift, u aren't planning on wheeling it like that.
It's more of a street rig this time around. My last JK 2 door pic in sig had everything and anything done to it. This JKU will be more street then off road.
-Brad
