First to fill Snorkel with water
#61
#62
Location: Hangin in the sunshine state....staging forum..
I go UNDER the water
now just remember to adjust that snorkel when you get it
#63
Wait till they see the pics of the install of Toms snorkel in the wharton dirl lot moments before we go sailing with our JK's...
#65
not fast I pulled up to the puddle stopped and then hit the gas, well I floored it but it is a 3.8 lol
it is NOT a pond, its not a typical puddle either, this was in Ocala National forest FL, the puddle did not exist, not even a drop of water back in April but when you have 14+inches of rain in a few days it makes puddles where there were not puddles before
I believe you have a career as a tester of equipment. If you can't break it, it's good to go.
So was this an off trail pond? Does not look like your typical trail puddle to me. As big as it is, I don't think you caused any more erosion.
You need one of those little propellers for your hitch receiver except yours needs to work.
#66
cool photos, looks like your Jeep is going rafting. All you need is a good paddle and she's ready.
Do you all check your axles every time for water or had any issues? I hope the breather tubes are extended and/or temporarily sealed off for that kind of water.
#67
breathers are all extended
https://www.jk-forum.com/forums/jk-write-ups-39/breather-tubes-extended-46802/
#68
Well I finally did it, I always thought I maybe the first to hydrolock with a snorkel, I came as close as you can without actually hydrolocking. I fill the intake hose with water. It got into the intake but I stalled out before blowing the motor.
Well there was a BIG DEEP Puddle so I went thru it really fast like I always do and it lead to this, My intake tube FILLED with water and some got into the intake, we took the throttle body apart and cleaned all the water and mud that we could get to in there, took the plugs out, it still turned over thank fully the guys with me knew of a product called sea foam that they use on boat motors but you can use it on any. We got me back together after cleanign it out and then I discovered my one plug wire broke when I was taking it off. So I had to limp back to camp on 5 cylinders, then I rode shotgun for awhile then we went to auto parts store, then it poured all night so sunday am I finally fixed the plug wire and poured in the sea foam and it started up and ran good
couple pics, thanks knottymaid
I just want to say I did make it out of this hole, it was when I turned around to run thru again that my engine stalled and then I checked the air box
