You want HOW much???
Old 02-09-2009, 11:17 PM
hawgrider1200's Avatar
Default smoking or drinking???
sumbuddy said what r they smokin well they might be drinkin instead. I could drink that good scotch for that kinda money. good god, I'll do both of em for $135 and still drink that good scotch. (i think i'd wait untill i wuz off work b4 i started drinkin though)
Old 02-09-2009, 11:26 PM
odin725's Avatar
Did you ask them how much it was without the BJ?
Old 02-10-2009, 08:49 AM
mikejwil's Avatar
Not just the Rubicons... The JK D30's have drain plugs too
truly E.A.P. (easy as pie)
Old 02-10-2009, 11:54 AM
scouter4life's Avatar
All you need is a socket wrench (extension helps, but not required), a pan to collect the old fluid in and the new fluid. It's easier than changing the oil.
If you take the cover off for the full cleaning, I reccomend getting the Lube Locker seal vs. using RTV. Yes it costs a little more, about $15 per diff, but it's super easy and will last a long time and handle a lot of abuse.
Old 02-10-2009, 12:22 PM
skibum's Avatar
Local dealer in Concord, NH wants $220 per axle. Do they think we're all stupid or what?
Old 02-10-2009, 01:27 PM
hig4s's Avatar
Originally Posted by RubiJK
AND... you have to wonder what cheap azz gear oil they would put in also. I did both mine myself with top of the line Royal Purple for a total of $35 and 20 minutes (I had a cig in between!).
The dealer will use Mopar Synthetic.
Royal Purple synthetic, Mopar Synthetic, and Lucas Synthetic gear oils all when tested, rated worse than Castrol, Pennzoil, and Valvoline dino gear oils.!!!!!!!
http://www.synthetic-oil-tech.com/Ge...te%20Paper.pdf
Old 02-10-2009, 08:11 PM
MOWrangler's Avatar
Got it back today and the line item on the receipt indicated that they did indeed put new diff fluid in the front after replacing the seal. Hehe... $135 worth of diff fluid charged to the warranty!
Old 02-10-2009, 08:54 PM
Big A's Avatar
Good info to know...
I am assuming you went to Youngblood?
Quick Reply: You want HOW much???
