X or Rubi
#23
I think i have the only x in town but i wave to everyone and for the most part they wave back even the tj's. I haven't found anywhere that i cant get to in the x but i would like to add a lift and some tires. the main reason i didn't get a rubi is that it was not available with out power windows and locks and a bunch of other garbage that i didn't want.
#24
And Coy I knew you were stirring the pot just by reading what you posted
#26
So, where does the Rubicon have an advantage over my high-end X? Rock crawling and deep mud. It's built for that. On normal trails it has no advantage at all. Ditto on the beach. If you need 4 low on the beach, you've already screwed the pooch. My LSD means I have better traction in 4 high. The Rubi has open differentials unless in 4 low, where the lockers can be switched on. Rubis have a more durable front axle for severe work.
Inasmuch as 95% of JK drivers spend the overwhelming majority of the driving on paved roads, the advantages of a Rubicon shrink to insignificance. In contrast, a well equipped X sees its advantages come to the forefront. The stock Goodyear SR-As are much better in snow than the BFG MTs. They are also much quieter and provide for a significant increase in fuel mileage due to lower rolling resistance. Add to that a more economical rear axle ratio.
My X has the heavy duty suspension, 32" rubber and the same ground clearance. For less than $400 you can add factory rock rails and an evap skid plate. Another $600 will get you a set of MT tires on steel wheels. Windshield mounted side-view mirror is well under $100 for when the doors come off. Lighting kits are inexpensive and easy to install.
In short, unless you are planning to get into hardcore off road adventures on a regular basis, skip the Rubicon. Buy an X or even a Sahara. Spend the money you save on equipment and mods that will suit the type of use your JK will see.
The fact is that you can build a X into anything you want, but you don't need to spend the extra $$ for something you may never really use or need.
My regards,
Widewing
#28
We bought the Rubi. We could afford it, and it's got the options for wheelin' so, I won't have to spend the time nor money to get the goodies it came with. I've got an '86 Bronco that I have spent years under, While it's fun to work on. The Rubi has in it what i spent a couple of years and a couple of thousand dollars doing to the Bronco. I built my own axles for the Bronco Dana60 rear, 5.38 gears and a Detroit locker. Just in parts....$1200. Dana 44HD in the front, around $1400 in parts. It was kind of wierd to drive one off of the dealer lot that has more wheelin' option than one I've had to build out. At half a century old, it's getting harder to get under the rigs any more.
Bob K.
Bob K.
#29
Bob K.
Bob K.
