Write up on Differential oil change
Does anybody know what they actually do at the dealership for the Differential Service?
Is it just the fluid change, or do they remove cover/clean/re-RTV? Mine quoted $190 for the service.
Thanks,
D
Thanks,
D
Changed Oil, T-Case, and both Diffs today myself in about 2 hours for the scheduled 15K service. Added the T-case just for safe measure, not scheduled until 30K. First time I've ever done any of them. Piece of cake with the Project-JK write-ups, thanks.
Diff fluid was rather dark, needed to be changed for sure. Some metal sludge, almost like anti-seize on the magnetic drain plug. Wondering if I had water get in at some point. The front only took just over a quart, and the rear just over 2 though, less than the write-up said.
T-case fluid looked like new.
Mobil 1 5W-20 Oil, 75W-90 Gear Oil, used the Mopar ATF+4 Trans Fluid and Oil Filter.
The T-case isn't on the 'Schedule B Maintenance' - suggested here in VT - until 30K.
Since I just went on a 4 day Jeep, 330+ mile trip with significant time in 4LO, figured I'd go ahead and do it early at 15K. It was only around $20 in ATF+4 Fluid and a half hour of my time. Worth it just for learning and piece of mind.
