Winter Tires!!
Winter Tires!!
Well openions are like a$$holes everyones got one and most of them stink haha jk!!
Heres some pricing on some winter rubbers. Looking for anything good or bad about any set.
Any openion or experiences are very welcome!!
BFG winter slalom $150 each
Michlen LTX winter $220 each
Dunlop grand trek $165 each
Bridgestone blizzak $231 each
When I lived in Edmonton it was so damn cold that pretty much any tire would stick, sorta like driving on hard beach sand. In southern BC where it was warmer and the snow could get like greased snot, the rubber compound in the Blizzak was best. Blizzak rubber would also work well on the Edmonton side streets when they get as slippery as the ice cubes in your drink - 'specially during spring breakup.
For winter conditions narrower tires work better than wider tires because you get more pressure per square inch of tread. Its the opposite of trying to float over mud or loose sand where wider tires rule.
I used to do the same, get winter tires. then opted to just screw it and got duratracs. best decision I ever made, just run them year round. Winters in Nebraska are shitty too, very icy and wet generally. these grip like a champ and dont have to store a set of tires then. but if your set to do a set of winters only. blizzaks
Goodyear Duratracs excellent for all year round. They scored the highest for an A/T tire. They scored a 3 in sand, rain, mud, rock, and they scored a 4 on snow and ice. Check them out, you will not be disappointed.
But as mentioned if you're looking at winters only BLIZZAK
I live at 9K feet and commute 2 hrs to 800 feet and I love the Rocky Mountains. The snow can get to 3-6 feet and I have yet to have an issue for 2 winters with these tires. You get more spin from the Falkens but thats why they are so great, they dig forever and you get traction and never look back.
I have also had the duratracs, they are equally great, but wear alot faster and the buildup between the treads is horrible, potentially putting you in a sticky situation.
In the winter I run my Falkens at 26lbs and lower to 19lbs when the black ice builds up getting off the freeway. For the price, you cant beat em.
