Where to Jack from
Where to Jack from
Got a new HI-Lift for x-mas, What is the recomended point to use this jack on a stock rear JK bumper?
Thought I would ask before I need it. I also have a Smittybilt SRC fron bumper so feel free to make suggestions for that also.
Thanks
Thanks
Indeed, I found a 19"+ double ram bottle jack on the web. Inexpensive, and it will lift the Jeep plenty high. It's made by Torin and can be found at Northern Tool & Equipment. Add a 2" block for additional height. I've used bottle jacks to get vehicles unstuck in deep sand.
I've used hilifts for years. I carry one as a multi tool, not so much because it's a jack, but because it can be used for just about anything (winching, straightening, splitting, lifting, prying ect). If you want to change a tire, use another type of jack. If you have a tow receiver in the rear of your jeep, you can use the hilift to jack off of it. Use a d-ring clevis through the hitch and jack from that. It's a good way to get the back end of the jeep up to stack rocks under the rear tires.
Great idea on the d-ring as a lift point. I don't use Hi-Lifts for tire changes, instead use a good bottle jack, but they are great for getting off of rocks etc,.
