What's the tool or item you never go off road without?
Old 02-26-2011, 08:46 PM
thelouv's Avatar
Default What's the tool or item you never go off road without?
I did a quick search and did not see this asked yet.
What do you have in your tool kit? The one you keep in the Jeep and never go trail riding without.
And maybe seperately. What do you have in that big tub of off roading stuff? You know, it's not always in the Jeep but when you're gonna be on the trails, you make sure to pack it along.
For me, Tool kit: of course the usual screw drivers, pliers, utility knife, zip ties, socket set, wheel lock socket, duct tape, and added this last week (cause we need it on a recent ride) a small hack saw, and safety pliers (with a small spool of wire).
Off road tub: tow straps, shackels, tree savers, extra bungees, toilet paper (can become a woman's best friend having this), cane knife, sledge hammer-2lb, mini-air compressor and tire plug kit, cam buckle straps, jumper cables, receiver pin, extra leather gloves, and a rain parka.
I guess what I'm really looking for here is that item you needed once and now have in either of these kits. Like us last weekend needing to cut a crimped joint from a metal transmission line (hack saw) without crushing it and attaching (for a trail fix) the rubber hose to it (safety pliers and wire). Hey it got him off the trail and back home 2 hours away.
Old 02-26-2011, 08:59 PM
33 williys 77's Avatar
Lubs, oil, atf , and what not like a little ditty stock
Old 02-26-2011, 09:04 PM
PainKiller's Avatar
tools, recovery gear, all the usual stuff , but I just purchased a 36MM socket for the axle nut. After seeing what can happen to axle u-joints and yokes I will carry this on outings "just in case" . If I break I will be able to remove it on the trail
Old 02-26-2011, 09:14 PM
fish's Avatar
Location: Apple Valley, California Good ole Mojave Desert.
water
Old 02-26-2011, 09:41 PM
Hellbound13's Avatar
Always in my Jeep..
Full socket set
Full wrench set
Breaker bar
1/2 inch drive ratchet
Pliers
Vise grips
Screwdriver set
Gloves
Old 02-26-2011, 10:05 PM
SoupSandwich's Avatar
Normal tools, with an impact set.
Old 02-26-2011, 10:22 PM
captjay's Avatar
Originally Posted by toad
Mine is 35mm.
I have 3 tool bags that I always take with me, no matter where I go. Having air deflators as well as air to air back up with is definitely handy to have.
if it makes u feel better, i had one side that was 35 and the other 36. yes both were stock. explain that one????
i keep 35mm and 36mm sockets, all the tools to be able to pull the axle out if need be. my towing gear,. ie snatch block, straps, etc... always stay in there
Old 02-27-2011, 01:35 AM
ARinmyJK's Avatar
Glock 20.
Old 02-27-2011, 04:19 AM
Lazurus930's Avatar
Condoms, never know when your gona bump into a hotie on the trail. Lol
Old 02-27-2011, 05:36 AM
howitzer's Avatar
9mm - never know when your gonna run into deliverance on the trail!
Quick Reply: What's the tool or item you never go off road without?
