What gas do you use 87, 89, 93 ?
Old 10-22-2009, 05:47 AM
  #41
smbundy13's Avatar
the manual says that you should put 87 octane and that if you put higher than that it could actually hurt performance and mileage.. not sure if that is correct but that is what the manual said.
Old 10-22-2009, 05:52 AM
  #42
GoodysGotaCuda's Avatar
No reason for more than 87 on a stock tune..
Old 10-22-2009, 07:02 AM
  #43
dlt1cy's Avatar
Doesn't timing adjust automatically? If you use higher octane to say 89, wouldn't that raise the ping threshold and therefore advance timing for higher performance?
Nevermind, "peak" timing map probably is not set for anything higher than 87. So if 89 shows any improvements, it's probably because the 87 previously used was garbage and the 89 is just bumping you to where a normal 87 should be. Sorry for the rambling, I am just thinking outloud.
Old 10-22-2009, 07:12 AM
  #44
Alias's Avatar
87 for me as well, I already want to cry when seeing the price when filling up a full tank. don't want to make it worse.
Old 10-22-2009, 08:51 AM
  #45
whpony96's Avatar
It depends on the tune I'm running with my Flashpaq.
Old 10-22-2009, 12:37 PM
  #46
Originally Posted by EmbarkChief
Without a tune you are wasting your money putting anything in higher than 87.
IT ACTUALLY MAY GET WORSE. IT IS DESIGNED TO RUN ON 87 AND NOTHING BUT. UNLESS OF COURSE YOU TUNE AS STATED ABOVE
Old 10-22-2009, 12:39 PM
  #47
spinlock's Avatar
91 with 91 tune.
Old 10-22-2009, 01:44 PM
  #48
EmbarkChief's Avatar
Originally Posted by Dawzz
89 with the new tires and my steep road and driveway..... was getting some ping on the hill
runs MUCH better with the 89 for the quarter a gallon difference
If it's pinging on 87 then something is wrong, how many miles on your JK?
Old 10-22-2009, 01:53 PM
  #49
SaginawMike's Avatar
Octane requirements are dictated by compression ratio only. 87 for stock rigs is all that is required. Anything else and you are throwing money out the window. Tuning has nothing to do with it. Tuning is required if you make major changes to the engine such as new heads with a higher compression ratio. You tune to the design. Just "tuning" with a reprogramer and adding higher octane fuel will do nothing but make you FEEL better. Put it on a dyno and prove it.
Quick Reply: What gas do you use 87, 89, 93 ?
