Were to find a replacement cable for my winch
Whats up Guys This weekend I was helping out my Father in-law take down a sycamore tree and we used some chains a 5/8 steel cable and a 30,000lbs snatch block and my winch xrc10k. I had my Jeep tied off to a pine tree because I kept pulling my self with the winch.
While he was cutting on the tree, I was keeping tension on the line to help prevent the tree from going backwards in to the highway. And after the tree fell I was unhooking everything and noticed my cable was looking very questionable. I have a xrc10k winch and I can not seem to find a steel cable replacement for this size. I have looked on Smittybilts website along with quadratec, northridge, and 4wheel drives web site. Am I missing something because all I can seem to find is synthetic line. Does anyone know were I can locate one?
If you don't want synthetic try a local rigging shop. Not only will they have the right size wire rope they will be able to swag ends. You can also pick up a swivel hook and have it installed. I replaced my winch line on an warn 9500 I used to have and it was significantly cheaper to have it done locally.
Not to be rude but I could only find synthetic line on your website. And a hand rigging rated for 5klbs.
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
![](https://www.jk-forum.com/forums/images/ranks/veteran_air_force.png)
Synthetic is a lot safer during the winching operation because it doesn't store the kinetic energy that wire rope does. It doesn't have the weight of wire rope. It won't have the broken strand ends that puncture an unwary palm, and won't form bends, snags and kinks that plaque wire rope. It won't rust. For these reasons, synthetic line is now mandatory in virtually all off-roading competitions.
It is subject to abrasive damage that doesn't affect wire rope as much. Because of that, a good synthetic winch line will come with a Kevlar shield to be placed where the line may come into contact with an abrasive surface during the winching operation.
Cost is a great reason to buy steel cable. If cost is not an issue, then all four-wheelers should opt for synthetic line.
