water in my JK
water in my JK
So the local area around me is underwater due to recent storms and while helping people out I was submerged to about the top of the hood, or about there as I was told by spectators. I didn't stop nor depress the clutch, got out of the water and left the jeep on for 30 min. I then drove around a bit threw some seafoam in the gas and filled it with mid grade and ran for a few more min. After I got out of the water I inspected the Airbox, there where a few damp spots but not much. Do I have anything to worry about and what do I need to to to make sure there isn't any damage?
On a side note, IT WAS SO AWESOME!!
PPS, without my teraflex leveling kit my hood would have been submerged and I would have been Fu*ked. thank's teraflex for giving me the extra 2" to help alot of locals!!!!!
search it out man lots of threads... basically the water and mud gets into the clutch causing failure.
Joisey- change your diff fluids as I am sure you submerged your diff breathers being that deep
I have that planned, but how long do I have? It's pooring out right now.
also diff oil change will take u no longer than 20 mins!
the sooner the better.. u might want to extend the breathers for future rescues!! the front and rear vents are not much higher than the top of the tire. front is even with top of shock, and rear is just inside frame rail.
one is on the drivers side front runs parallel to the shock but I dont know where the rear isjust find the hose on the diff and follow it up. definatly change the fluid sooner than later
Yes there are, they are right behind the engine on the firewall. Damned nearest the hardest place to get to to work on them. I have yet to extend mine...
