Truth about motor oils and how they perform
IMO people would be better served to choose an oil based on real world experience than one single test that doesn't prove much of anything at all.
The author himself said that this test was only based on one aspect of these oils and different tests could show far different results.
I've ran Mobil 1 for a lot of years. I've ran numerous used oil analysis reports on the different engines I've used it in. I've yet to have a UOA come back stating that M1 wasn't doing an excellent job at protecting my engines.
I'll continue to use M1 until the UOAs come back saying its not working well in my engines. I'm not going to switch based on a SINGLE internet article.
If you change your oil often and don't run your vehicle 24 hours a day, most synthetic oils will be fine. I have run Mobil One in my Jeep and the cheaper Valvoline Synthetic in the wife's car with no problems.
"Between 1935 and 1972, The Timken Company produced and sold a lubricant test machine that was used to determine the EP (extreme pressure) characteristics of grease and oil lubricants. It became an industry-standard test. A bearing race is mounted on a tapered arbor that is rotating at a high speed. A square, steel test block is then loaded against the rotating race, with the contact area flooded with the test lubricant. The load on the block is increased in increments until the oil film is broken and the spinning race produces a score mark on the test block. The load-value that produces the score is then called the Timken “O.K.” load rating.
It was generally assumed that the higher the O.K. value, the more load the lube could hold without the film strength being compromised. However, this is not necessarily the case, and the primary purpose of the test is to determine whether or not the lube has an EP additive. Values higher than 35 lbs. indicate the presence of an EP additive."
Where did I find that quote? From the Timken Corporate website. I think you folks using Royal Purple will be fine. As for me, I'm sticking with Mobile 1--As I have since the mid-70s.
