Tops
Lots of threads on the Trektop NX. I have one for my Jeep and I've only ever had one issue with it. The back cross bar does not stay clipped onto the soft top but the tension of the straps that hold the top on keep it in place. I subsequently broke the plastic on the cross bar and just leave it mostly loose.
It doesn't take much time to get it on and off. The windows slide in fairly easily but if it is cold outside the material shrinks pretty good and its very tight to get zipped up. It takes me about 5-10 minutes to get the whole top on myself (with the door surrounds and mounting bracket already installed). The top works great as a bikini and that is how I drove around most last summer. You just have to remember to tighten the rear straps when you fold the sunrider back. Without the windows the top gets pretty loose with the sunrider back and I had the straps come off and the top flapping pretty bad while I was driving down the highway (had to pull over right away and put the straps back on).
The Best Top YouTube channel has the installation on it and I followed it step by step when I installed it. It should give you a pretty good idea of what is involved.
