View Poll Results: Which T-case failed.
Voters: 22. You may not vote on this poll
T-Case Failures. Who's had them?
#31
I wonder since the exhaust piping is like 3 inches away from connection between the shaft and transfer case, this heat is fubaring the stock shaft, and if their is a double carden after market in that area heat expansion is causing increase in vibration resulting in kaboom.
#32
My research has indicated 3° max, and even that will cause some vibration.
#33
this thread right here, while only a small amount of members are reporting issues, is a scary one...
Im running 35's, stock 3.73's, lifted 4" and have Tom Woods front DS, I do a lot of highway driving. and I can tell you right now the angle at my pinion is much more than 3 degrees.. In order for me to adjust my castor the way I liked it, the pinion is at a fairly large angle.. its about parallel to the ground. I will say tho there is no vibration that I can tell...
Wonder If I have anything to worry about
#34
Your 3.73's and 35's may have prevented you from hitting the critical drive shaft rpm at the speeds you have driven so far.
I have seen vibration tests on electronic equipment for the military.
Every piece of equipment had its own critical frequency. As the frequency was turned up, I watched the fasteners back off to the point of falling out. If the frequency was adjusted rapidly through that point, so the fasteners remained in place, at a certain frequency, the piece of equipment would explode. The thing is, you can't see the piece vibrating, so it's not like it is being thrown around.
#35
What im thinking.... gears (5.13's) and high speeds.. the DS must be spinning VERY fast.. probably faster than I can even duplicate with my stock gears at 100 MPH
Im wondering, IF we all keep our speeds relatively low (65, the local speed limit here is only 55) the chances of this happening should be minimized, and Ill be adjusting my arms to line up the pinion a bit closer to 0.
To me, this pretty much seals the deal that I wont be doing a regear
#36
Vibration can never be eliminated. You can, however, move the critical point up or down the scale.
A regear can be offset by larger tires.
I have noticed in the cases here, they were regeared and had bigger tires, but the combination still resuted in a higher drive shaft rpm for a given road speed.
#37
IT appears that Transfer case explosions occured with gear ratios >4.1, am I correct? Did this occur with older TJs, other vehicles? Or is the RockTrac just another shotty piece from Chrysler.
#38
It's not just the RocTrac, (look at the poll) and I don't think Chrysler made them.
#39
Don't know how many of you have noticed that our tcase sits at about a 5 degree angle up towards the front. It doesn't sit level. Seems to me this may help contribute to the poor angle we have to run in front for castor, maybe even poor lube of the front bearing. On the auto tranny anyway.
#40
It might be a factor regarding front bearing lube if you also consider lifted JKs have probably eliminated the stock forward rake, effectively tipping the t-case back a little more.
