View Poll Results: Which T-case failed.
Rubicon Rocktrac
63.64%
Standard T-case ( X/Sahara)
36.36%
Voters: 22. You may not vote on this poll
T-Case Failures. Who's had them?
Old 01-14-2010, 04:00 PM
JK-Forum Founder
wayoflife's Avatar
well, you know that i went through one and trail bud did too. i'll try to dig up pics and post them later. FWIW, both t-cases are the same, just different planetary gears i'm pretty sure.
Old 01-14-2010, 08:47 PM
RokinRubi's Avatar
Here's mine
Old 01-15-2010, 05:46 AM
Littlejon's Avatar
I didn't vote since I didn't have a catastophic failure, but my spud shaft had a bad casting that damaged some of the seals on my transfer case causing a very small leak (like a few drops per day by the time I found it). The dealership couldn't get just the seals as fast as a whole transfer case, so that is the route they took under warranty.
If I didn't pay attention when I have a few drops under the Jeep and let it go for a few thousand more miles it wouldn't suprise me if it had been like these catastophic failures.
Old 01-15-2010, 07:34 AM
JK-ADD77's Avatar
RokiRubi,
What the story? How did it happen?
Old 01-15-2010, 08:27 AM
RokinRubi's Avatar
I was driving to back up to school, cruising about 70 when i felt a slight vibration before I could slow down everything just blew up. I ran into the center median and jumped put and had to use my fire extinguisher to put the fire out. Pretty scary.
Old 01-15-2010, 08:50 AM
ronjenx's Avatar
I see in your profile you had all the ingredients (i didn't see regear, though) for the explosion. Including the front drive shaft with the double cardan at the case, and single at the pinion. Can I assume the front pinion angle was greater than 3°?
Old 01-15-2010, 03:16 PM
Ryanc's Avatar
Are we talking the front driveshaft or the rear causing these ticking time bombs?
Old 01-15-2010, 03:33 PM
ronjenx's Avatar
The cause hasn't been established yet, but it appears the damage is on the front of the t-case.
Old 01-15-2010, 03:47 PM
Ryanc's Avatar
If you use a double carden on both the connection to the transfer case and axle eliminate the vibration that is suspected to cause this problem? It would seem to me that a double carden connected to the transfer case, and a single u joint connected to the axle would not dampen enough vibration.
Old 01-15-2010, 04:00 PM
ronjenx's Avatar
A double cardan on the t-case requires a near 0° angle on the single joint on the other end. Proper damping will result. It's main advantage is the t-case and pinion don't have to be parallel.
A double cardan on both ends would allow the shaft to flop around. At least I think it would.
Quick Reply: T-Case Failures. Who's had them?
