Stupid TPMS!!!!
Old 01-01-2008 | 06:45 PM
79shark's Avatar
Default Stupid TPMS!!!!
Ok, the idiot light has been on and buggin me long enough that I decided to do something about it. The light came on when it started getting colder, which I anticipated would probably happen. So I bumped up the pressure in each tire to 34-35 lbs, the light stayed on. So then I read another thread about doing the spare tire too, so thanks to whoever put that info out, I hadn't thought of it. So yesterday I check the spare and bump it up to 36 lbs, aong with the rest of the tires up to 36. Light went off for a day, now it's back on. The temps have dropped to the teens and single digits since I last did this, but it shouldn't affect the pressures that much to where it trips the sensor.
Does anyone know at what pressure the sensor is supposed to trip? I wouldn't think 2-3 pounds would trip it, but maybe I am wrong. Also, have any of the electronics guru's here figured out which wire goes to the dash light for the TPMS system so another (i.e. ESP, Lockers) toggle switch can be installed somewhere? THAT would be a great write up.
Old 01-02-2008 | 05:03 AM
BaltChief's Avatar
It is suppose to trip at 25% of the pressure that it is set for. I found that to be a little inaccurate on mine. Mine were set for 35psi and it would go off at 31 psi. I now have them set for 30psi and they don't trigger the alarm until 24psi
Old 01-02-2008 | 06:11 PM
Money Pit's Avatar
Assuming that there isn't a problem with the TPMS, can't you have your dealer fill your tires with Nitrogen? My brother told me about it as the gas doesn't expand and contract drastically like air. He had a problem in one of his cars with Tire Pressure Sensors and that solved it.
Just a thought....I think it costs like $100 or so.
Old 01-02-2008 | 06:32 PM
fullthrottle's Avatar
mine go off constantly,checked it today all were within 1 pound of each other made them all the same and it went away ^&#%$ junk
Old 01-02-2008 | 09:06 PM
IndianaJK's Avatar
A friend of mine sugested that we buy some heavy 4" PVC tubing and cut it about 6-10 inches long Drill 5 holes in it and install the TPM sensors in it. Then cap both ends of the PVC pipe. Air it up to 32 psi and stick it in the back, under the seat, or strap it under the Jeep.
At 32 psi there is realy no danger at all. I have PVC pipe feeding all the air supply at my shop and it is always at 100-130 psi.
Ok, I sugested this in another thread any many people thought it was a good idea. Others thought that it would not work because they said the tires have to spin to report preasure.
My question is , How does the spare tire report its preasure if not spinning?
I think my idea might work if the computer just takes a preasure sample every once in a while.
I plan on giving it a try this summer unless somebody else tests this out first.
I like to switch out my custom wheels (I dont have them yet) with my OEM wheels durring the winter months. Even if I spent the 200+ on 4 sensors for my new wheels I would still have to go to the dealer to have the sensors rematched to the computer everytime I swaped my tires/wheels.
Old 01-02-2008 | 09:34 PM
bikerglen's Avatar
The spare still reports; it just reports less frequently than the tires that are spinning. Also, there's a bit in the message that indicates if the tire is spinning or not when it does report. Don't know if the ECU pays any attention to this bit or not.
Anyone know how to build a 315MHz FSK transmitter? We could solve the TPMS problems once and for all.
-Glen
Old 01-03-2008 | 05:00 AM
bertjnkns's Avatar
From: East Texas or Shreveport depending on the day
Ok, I don't have this on my jeep. But what happens when you air down on a trail? Do you just have a continuous alarm?
Old 01-03-2008 | 05:45 AM
79shark's Avatar
Tires are already nitrogen filled from dealer...thanks for suggestion though.
Old 01-03-2008 | 06:09 AM
Bondsman's Avatar
I am only running with 4 tires.. Spare removed for the last 1000 miles... Pressure set at 30psi and no light (yet). I don't know how often the spare should report, but it should have within 1000 miles.
