Studder
Studder
Hello fellow Jeepers, I have a problem. What I am experiencing is at low MPH I am getting a studder. It's really weird it's not like it's cutting out but feels like a studder in power but only when I'm going around 20-30mph. Any idea what this could be??? Any help would be great.
I read on your profile that you're in an '07 automatic. The first thing I would do is make sure you have all the recalls taken care of. I know that the '07s had some bizarre firmware issues that caused all kinds of issues.
If that's not the problem, I think we'd need more info to diagnose the issue. I have an '07 auto and have no similar issues. Does it only happen when it's in drive, or in neutral at low rpm? I know that sometimes if you're low on transmission fluid or need a transmission flush that it can kind of skip when changing gears.
Good luck
Micah
Good luck
Micah
Unsure of recalls but I will check and see if there are any outstanding. I have 75k for miles. It seems to only be in drive that I notice but then again I don't typically drive neutral. I will do my plugs this weekend and maybe that will be the fix. Hopefully it's something simple. I will update when the plugs are changed.
