stuck on side of road
Old 07-19-2012 | 12:55 PM
LSUfan1978's Avatar
Default stuck on side of road
Hit a huge puddle. Have a 2010 jku with a k and n cold air intake. Jeep sputtered and now wont start...
Old 07-19-2012 | 01:58 PM
k0260's Avatar
no bueno... I know that CAI are easily prone to sucking water, hopefully if it did ingest water, it was not much. You'll want to change your oil, pull your spark plugs to see if and how wet they are, and blow the water out. I'm sure someone will chime in here though that can give you better details than myself. Good luck
Old 07-19-2012 | 02:04 PM
mkjeep's Avatar
Did you check to see how wet your air filter is?
Old 07-19-2012 | 02:29 PM
LSUfan1978's Avatar
Air filter seemed pretty dry. Airbox was a little wet though. My local guy said he will look at it tomorrow. He is pretty reputable, but thinks that it might have sucked in water. He had another one in January that did the same thing. After 2 months Jeep agreed to replace the engine with a used on. Hopefully its not that bad.
I tried to start it right away but it wouldn't turn over. Close, but not quite.
Old 07-19-2012 | 02:30 PM
LSUfan1978's Avatar
Ran my fingers thru the filter and it was slightly damp, but not wet at all.
Old 07-19-2012 | 02:34 PM
BlackdogJK's Avatar
Worst case scenario you hydro locked the motor. I had a cai on an old car and had quite the scare with it. I swore I'd never get one again. Check filters, plugs, oil and your oxygen sensors. Best of luck.
Old 07-19-2012 | 03:00 PM
LSUfan1978's Avatar
Hoping it was the starter or plugs got wet. I dont know a whole lot about motors.
Old 07-19-2012 | 03:02 PM
Dralphy's Avatar
Unfortunately I doubt Chrysler will replace a motor when there was a CAI involved.
The only thing this sounds like is a hyrdolock. Hopefully it didn't ingest too much water and your guy can get it back running quickly.
Good luck..
Old 07-19-2012 | 03:34 PM
Runewolf1973's Avatar
Actually, my dealership specifically warned me about this... They said if I installed a cold air intake and got water in my engine it would void the warranty on my engine. Hope it turns out to be something else though.
I wonder if accidentally hitting a huge puddle could be considered an Act of God under insurance?
Old 07-19-2012 | 03:37 PM
JKBobAZ's Avatar
And people laugh at my Snorkel!!!
I filled up my OEM airbox with mud before the Snorkel
