stock stereo with new speakers?
I know this has been answered as I have been doing lots of research on the topic, but what are your opinions on keeping a stock, base model head unit while upgrading the speakers and putting in a powered sub?
I like the look of the stock h/u but want a better sounding system. I've read that a line out converter is the way to go. thoughts? testimonies? I would also most likely be installing an amp for at least the front speakers.
any feedback is appreciated
I'm looking to do something similar with my stock HU, except even less than what you want to do, I'm probably just going to change out the stock speakers. Quadratec and others sell a drop-in speaker upgrade from Kicker and it's supposed to make a big difference. There's plenty of options for a stock speaker upgrade, check out Crutchfield.com. For guys that like big sound, just a speaker replacement is probably not enough, but my goals aren't to have a crazy sound system, I just want a fuller and brighter sound (being able to hear some bass, and having the high end not sound like someone singing over a telephone). I'm sure adding an amp and a boom-tube will help even more in your case.
you're in the same boat as jk_sea. i think a line out converter is necessary for upgraded speakers to sound good with the stock h/u
I have the very stock head unit (base model, no nav, no u connect, plain as they come)
I added a kicker marine amp and the kicker DS line (same model as the kickers quadratec sells) for all 4 speakers and let me tell you, it sounds so much better than stock.
I used the PAC AOEM-CHR3 adapter for $35 and that is the best LOC you can get as far as adding an aftermarket amp. Plug and play adapter that gives you a 4 channel RCA output with no cutting, splicing, etc.
If you want to be able to crank at high volume and have everything tight and crisp with really punchy bass, then yeah, you're going to want to add an amp after the head unit.
I've done this before on a couple of my cars, for example, a 94 Chevy Camaro with 4 speakers and the crappiest of crappy Delco tape deck. It really does make a world of difference when you just change out the speakers (which are often paper and have some weak cruddy surround, small magnets, etc).
Neither the stock head unit nor the speakers are great. Just swapping out the speakers will give you fuller sound. But that doesn't tackle the fact that the head unit still isn't putting out a lot of power. The speaker swap option is for people that don't mind the stock head unit in terms of functionality, or listening within the volume range that the stock head unit puts out with stock speakers. The net result is a fuller, brighter sound within those volumes when the speakers are replaced with better ones.
Between the head unit and amp. It is just a harness that goes between the stock speaker harness and the head unit and it gives you 4 channel RCA outputs. Then you hook an aftermarket amp into these outputs, then your new speakers from the amp
