Stock Rubi -vs- Hi-Lift
From what I can see, the bumpers are worthless and the rock rails are questionable when it comes to using the Hi-Lift. I've read a number of conflicting opinions on the use of the Hi-Lift with a stock 2 door Rubi so I want to ask those that have actually used it.
Has anyone lifted a stock 2 door Rubi using a Hi-Lift? If so, where did you place the jack?
I value the Hi-Lift as a piece of recovery gear but I do not see a good place to use it or store it in the new Rubi. Since I'm planning to keep the Rubi stock and do not plan to do any rock crawling - hill climbing - mud diving, I'm debating about even carrying my Hi-Lift. The stock Rubi will get me where I want to go in the desert with no problem.
Opinions?
Opinions?
My Dad bought me one when I got my first truck; a '65 Chevy P/U. I chain-locked it to the spare after cutting a hole in the top of the bed to pass the chain through. I wish I knew what happened to it. It would be a classic today, 35 years old.
get the wheel hooks. i've used mine on the stock rubi rock rails a few times with no problems also. they aren't as thick as aftermarket rails, but they are pretty stout. you don't have to worry about hurting them.
From: Mountain View, CA & Incline Village, Lk. Tahoe, NV (summer house)
Fine with the stock Rubicon rock rails. It won't cause any damage to the body of JK. If you are worried, use a 2x4 wood block between the rock rail (JK body) and Hi-Kift.
The Lift-Mate works also.
