Steering wheel shimmy?
Originally Posted by Scoak
My steering wheel shimmy's/wobbles going around a turn at slower speeds. It just started happening.
What could it be?
What could it be?
Track bar not centered or loose??
I might be ordering an adjustable one...
Originally Posted by Yankee
If it turns out not to be suspension related, check your front axle u-joints for binding.
And if anyone has another opinion let me know.
Thanks
A shimmy at slow speed while turning is usually a loose bolt on either your track bar or drag link. Check them out first.
u-joint binding requires a fairly sharp turn, and it occurs only rarely.
Good luck!
Good luck!
Good luck!
Good luck!
Although the problem is likely what you suggest.
