Squeaky jeep
I just fixed a similar problem. The problem was the upper bolt on my passenger rear sway bar link was a half turn loose.
amazing, my jeep was squeaking a bit today, got under there and found both sides upper bolt on rear sway bar links loose. I knew what to look for as I had installed a lift a week ago and had not had a chance to retorque anything yet. all torqued up and runnin smooth and quiet.
Good luck being chasing similar thing for months now...
Putting rubber spacers on the spring perches this weekend to see if that does anything... everything else is tight and greased.
Don't forget to go under your jeep every time you have been wheeling to check all is tight greased and clean; it will last longer that way.
I had an annoying squeak as well. Turned out that one of my rear shock bar pins had broken at the fork. Lucky I caught it before the damn thing fell off on the highway or something. I got some JKS Bar Pin Eliminators (badass product) from Northridge4x4 and will never have that problem again.
