Soon to be jeep owner need advice
Hi there I am 10 weeks away from getting my 4 door Jeep wrangler rubicon unlimited and have purchased the freedom top is there any of you out there who have had problems with it , I am from Rainy Vancouver, B.C. and am concerned if it leaks.
Hi there I have been reading a lot of the responses with the Freedom top in general and there seems to be a general consensous that they have problems with the two pieces in the front section . do you know if therehas been any other issues with leaks and power shortages?
Do you know what would be the main cause is it due to the electrical shortages from the leaking of water or such do you know if there or where is the info about this that I could locate?
You can check out the TSB at this link:
http://project-jk.com/jeep-jk-tsb-re...nel-waterleaks
It's just a weatherstripping issue-- but like others have said, it seems to be fixed in the new builds.
My advice is to take some deep breaths. When your Jeep is delivered, test it out. Make sure everything works like you want. If they don't, talk to your Jeep dealer. If they won't fix it satisfactorily, don't buy it. Until then, I recommend thinking warm thoughts.
