Soft Top Trouble
Soft Top Trouble
I have an 08 4 door rubi with the soft top. The problem is on the driver side rear door. The soft top side is held in place by the rear door seal and velcro
at the top. Driving around this seems to work its way out at the top, starts catching wind and then pulls out even further. The other side seems to
stay pretty well.
Anyone else running into this? If it would stop raining I would just take it off!
Thinking about adding a narrow strip of velcrow to the back side of the plastic strip sewn to the fabric but it may bulge out too far.
Any help is appreciated.
stay pretty well.
You don't have the side windows installed right. There are detailed threads on it, but the plastic strip at the front of the window hooks into the groove and locks in. Use the search and you will see detailed pictures.
Will check it out.
Thanks
Its suppose to be tight. Get the zipper started and then starting at the top get the front plastic L started in the groove from the top. Work from the top til its locked in and then finish zipping it, then lock the bottom plastic L into the tub. But someone has already done a detailed ste of directions with pics I believe.
