SO ive got a tereflex 4" lift on the way...
Old 04-13-2012, 10:43 AM
LordEgg's Avatar
thanks. im just trying to understand better, not be a smartass at all, but what is the difference in fornt and rear vulnerability/build and why a pro rock front and not a pro rock rear?
Old 04-13-2012, 12:36 PM
Sponsoring Manufacturer
TeraFlex's Avatar
JK D30/D44 front axles can bend and even sometimes break the axles tubes in certain conditions. The rear D44's for the most part work great, however there are a few out there that have bent one. Yes you can run 37's on a stock front, but your better off bracing it or just upgraded the front housing with a aftermarket D44 housing. I'm running a Tera44 front and a Tera60 rear in my JK over the standard axles.
Old 04-13-2012, 02:35 PM
LordEgg's Avatar
if it were you, and money was an object (LOL) what would you do? What would it cost? What are the baseline needs considering that i will offroad, i will do more than simple rocky climbs, etc. I wont have Moab situations, most likely, but it will be used. I really appreciate the help. seriously.
Old 04-13-2012, 05:08 PM
mkjeep's Avatar
Originally Posted by Mr. Smiley
The Mopar 44 is just a dana 30 with a diffrent housing from what i have read. So yes, you will still want to beef if running 37's. You are going to want C Gussets, and mabey some Axle sleeves. Without these you could still run 37's but i wouldnt wheel it and would still be scared to even drive it on the street. 37's are alot of weight on these weak axles. Anything more than that and i would just start saving for a ProRock 44 up front.. and tehn buy the new axle, lift and tires all at once.. Hope that helps
Ahh yes, from what you have read. Half assed advice your giving here.
ID:	303652Click image for larger version
ID:	303653Click image for larger version
ID:	303654Click image for larger version
Name:	Moab 2011 315.jpg
ID:	303656Click image for larger version
Guess maybe I shoulda never wheeled mine then.
Old 04-15-2012, 09:49 PM
fifthconspiracy's Avatar
Here's my Teraflex 4" with 34s.
Very happy ;-)
Quick Reply: SO ive got a tereflex 4" lift on the way...
