Sill Kit
Old 01-10-2009, 12:36 PM
tango3065's Avatar
Default Sill Kit
Getting ready to place a small order with Quadrated or 4WD and was wondering if anyone has put these on and if so does the tape hold them on good?
http://www.quadratec.com/products/13113_202.htm
Old 01-10-2009, 12:42 PM
myklt8's Avatar
I got the powder coated SS ones from Rugged Ridge. the tape holds very well, just be sure and clean the area very well I used laquer thinner, but alcohol or any other surface prep should work. make sure that they are in the position you want them, they are a bitch to get back off
Old 01-10-2009, 12:52 PM
Wheelerbob's Avatar
I have those exact ones and they have been on for about a year now. No problems at all.
Old 01-10-2009, 01:54 PM
LedZepp877's Avatar
i got em, clean first and they hold great. no problems...take a beating too
Old 01-10-2009, 03:07 PM
wrnglrguy's Avatar
I've had mine on now for about 18months (first mod I did), and they are holding up like I put them on yesterday.
Old 01-10-2009, 04:09 PM
jmc
jmc's Avatar
I put the same ones on about 2 months ago and so far I haven't had any problems. With anything else that has tape, just make sure the area is clean and dry before you put them on. They makes a great difference in looks on the door sill.
Old 01-10-2009, 04:15 PM
fftri's Avatar
I've had them on for almost 4 months now.
Not to repeat what others have already said, I agree with all above.
I liked the fact that they gave more coverage on the front door sills
than others available. I have them front and rear w/ 4dr.
Old 01-10-2009, 04:24 PM
The Jeep's Avatar
I have them. No problems with them they have been on over 1 1/2 years.
Old 01-10-2009, 05:45 PM
gpb
gpb's Avatar
+1 to the others, these were one of the first mods I added to my Jeep.
Mine came with two alcohol prep pads (four-door). Just be sure to thoroughly clean the area and then press down hard once you've put them in place. should be fine.
Old 01-10-2009, 05:53 PM
armycop's Avatar
I have had them on both of my JK's they hold fine they should be standard from the factory. But buy them from your local dealer. Mine were cheaper from the dealer and they got them in one day.
Quick Reply: Sill Kit
