Seatbelt FLAPPING noise
#21
idk if I jus skipped over it but I didnt see anybody suggest running the belt on the inside of the plastic cover. there are three plastic rivets on the outside and two inside. I didnt have to take the outside three off, jus pull hard enuf in the right spot and the that piece will pop out enuf to run the belt on the inside of the plastic. no more flapping. ill post pics sometime tmoro when i get home
#22
#23
#24
Originally Posted by Venom19
This is exactly what I did. Works perfectly and does nit effect movement of belts at all. Simple, clean, and free.
#25
I found that the belt is flapping against the plastic cover where the belt come up from the floor. I went to an auto parts store, bought 2 cheap black seat belt shoulder pads. They are fairly thin and not very long. Put them around the belt down at the bottom in front of that plastic. Works perfect and you don't notice them.
#28
Please tell me i dont have the only jeep in America that does this ...its kinda annoying with the windows down but when you go doorless an topless its Horrible....the part of the seatbelt that goes from the shoulder bracket down to the floor that part of the seatbelt does some horrible flapping around....only thing i can think of is tucking it behind the lever that adjust the back of the seat...............
Anybody got any ideas?...
#29
#30
Originally Posted by BKGM Jeepers
I'm sure it's posted here, but a simple fix is using the Velcro cable ties to wrap the seatbelt tot your roll bar. cost is about 2 dollars.
