Rugged Ridge Pillar Switch Panel
#71
We have been working with these guys. As of today I have noted 4 complaints from the total number sold. After seeing the comments noted on this thread I had our current inventory spot checked for this and or any other visual defect. No pods were found with the warped edges. It’s possible that this was isolated to a carton that has already been shipped. We will continue to spot check inventory as it goes out.
The number of comments compared to the total number sold has been a very, very small percentage. None the less this does not make it good for those that received a bad part.
I have PMed the people involved and will be working with them and the retailer it was purchased from so that they are happy with the part purchased.
Today I received my switch pod from Q, cut out the lower switch opening sized a bit larger to accomodate a volt meter, went to install it and see that it is warped inward at the top where it contacts the windshield. As a result, the upper section where it contacts the windshield frame lip, the pod sits inside rather than over the lip. Are you sure this isn't a common problem? Can you please post a pic of what the fit should look like and also let me know how to get a replacement now that I have already cut one opening?
Thanks.
#72
Thanks.
Thanks.
