Rugged Ridge Pillar Switch Panel
Old 02-28-2011, 09:55 AM
  #61
TURTLECON's Avatar
Originally Posted by sully151
How are these different/better than just cutting into the current panel?
The OE panel is narrower and shorter, but depending on what you use, I'm sure you can cut and install smaller switches.
Old 03-30-2011, 11:59 AM
  #62
DTJK's Avatar
Originally Posted by ukie jk
Warped and rubs door. Looks like I need to take the heat gun to it.
My friend and mine are the same. I was hoping for a better fit.
Old 03-31-2011, 06:35 AM
  #63
wrangler07's Avatar
Originally Posted by BigRedJK
Pic in reference to my above post...
Old 03-31-2011, 11:43 AM
  #64
The_Yeti's Avatar
Maybe RR can chime in on the warped part. i'm wondering if they may have a fix for it
Old 03-31-2011, 12:11 PM
  #65
Former Vendor
Rugged_Ridge's Avatar
We have been working with these guys. As of today I have noted 4 complaints from the total number sold. After seeing the comments noted on this thread I had our current inventory spot checked for this and or any other visual defect. No pods were found with the warped edges. It’s possible that this was isolated to a carton that has already been shipped. We will continue to spot check inventory as it goes out.
The number of comments compared to the total number sold has been a very, very small percentage. None the less this does not make it good for those that received a bad part.
I have PMed the people involved and will be working with them and the retailer it was purchased from so that they are happy with the part purchased.
Old 03-31-2011, 12:40 PM
  #66
ke5rto's Avatar
I was thinking about getting this myself, but was curious if there were any momentary rocker switches available that will fit this. I want to direct wire my winch to this so I can operate it from the cab without having to run the remote all the way across the hood.
Old 03-31-2011, 01:01 PM
  #67
TURTLECON's Avatar
It's plastic. You can fit any switch into it that you can cut a hole for.
Old 04-01-2011, 04:54 AM
  #68
jeepcachr's Avatar
Yes they make a "momentary on/off", they also have a "momentary on/off/momentary on" switch so that you could do in and out on one switch if you wanted.
http://www.altex.com/Sealed-Lighted-...0-P142469.aspx
Old 04-01-2011, 05:41 AM
  #69
ke5rto's Avatar
Thanks, jeepcachr! That is exactly what I was looking for!
Old 04-09-2011, 03:23 PM
  #70
Cold's Avatar
ht tp://www.otrattw.com/proddetail.php?prod=VLD1A60B-AUCAT-100
Quick Reply: Rugged Ridge Pillar Switch Panel
