Rubicon and water
Rubicon and water
So i have a new 2011 rubicon And im not sure how much water can it handle, i mean, no roof at all and leave it parked outside should i worry about the rain?? Or not at all? It has gps and alll the features
Correct me if I am wrong as I've heard this a few times on various boards ... but there is nothing extra in the dash of a Jeep that makes it handle water any better then the next truck/car beside it. Ya it has drain plugs to help drain water if you wash out the floor boards with a hose but water coming from the top and hitting the dash/electrics has no protection, just normal wire connections as found in other vehicles. Just passing on what I've read numerous times, can't say its true or not.
That said ... I haven't been caught in the rain with my JK yet but more times then I can count on the TJ. The most common problem that I've read about (TJ & JK) is always due to the clockspring getting wet and damaged. As the previous posted mentioned, it's located in the steering column so if your leaving your Jeep out in the rain, personally I would at least throw a bag over the steering column to prevent that from getting wet.
I wouldn't let any part of the dash, steering wheel, front seats, or speaker bar get wet. They all have mass amounts of wiring, switches, and computer network interfaces. But then I'm a retired electrician and computer technician who has seen Murphy's law in action for too many years.
Its a real shame Jeep decided the JK should be a rolling computer network. Its just so wrong!
What we need is a plastic cover that could go over the dash for when you park your jeep.
Location: Native to Los Angeles, but migrated to Denver.
A little over a month ago mine was left outside at home while I was at work with the top down and we had a major T-Storm, filled the floor boards until it was overflowing. By the time I got home a few hours later the only problem I had was very wet seats and carpet. Everything worked just fine and I even have an aftermarket NAV/Stereo in it. I have also soaked the dash with the hose while washing it with the top down and had no ill affects to date.
