Rubicon is a rock crawling monster.
Well I spotted a used Rubicon for sale today and drove it around a bit. First thing I noticed was with the 4.10 gears by the time I was doing 35 mph it was already in 5th gear and loving it. Pulled it over to an area where I could put it into 4lo and man 1st gear with that 4:1 xfer case is really low.
Always figured that would be quite a trail rig and now after driving one there is no doubt about it. I don't want to get rid of my modified X just to get a rubi, but if I can't swing a deal for this one I am going to get one for sure.
If you are on the fence about getting one then don't drive one because you will be having to let loose of some more money to get one for sure. There is that much difference between the X and the Rubi. I mean it is like they are totally different Jeeps. I guess the only way it would be a bad thing would be if you did lots of highway driving, might get less fuel mileage with the higher rpms.
Anyway if you like running trails then there is no doubt about it the Rubicon is the one to get. Crawling with it is no problem at all. You only need 1st gear in 4lo if you are going over extremely rough or supper steep climbs.
I like it a lot and can't wait to get one to keep my X company.
hey man why don`t you just put a lil more money in ur rig? lower gears lockers and the rubi t-case if you want.. i would go atlas 2 but thats my personal choice... swap ur axels d44 or 60 and with all that its even going to be better than the rubi..
personnally i regret the choice i made buying the rubicon juste because the way i want to build it.. 37 or 40 inch tires, those stock rubicon axels wont hold..
just think about it cause i see you got good money spend in ur rig
my 3.73's, non-rubicon transfer case, and soon-to-be sway bar quick disconnects on my X are plenty at the moment.
waiting for the 12's to hit the lots, gonna test drive the piss out of one and consider a trade.
Just want to get a second vehicle and don't want a car. Can't do all the mods I want to do to this one until I get another one to use while work is being done. Love the way my little X runs the trails already, especially when someone says "your Jeep can't make that trail" and it ends up doing better than theirs.
Hope some of this makes sense.
Love my rubi. Dont plan on running more than 35s so the rubi fits me just fine. If I was going to build a monster It would be a stripped x and start from scratch.
