Rod holders
Rod holders
Has anyone mounted flush mount vertical black plastic rod holders into the OEM bumper? Was thinking of trying this at the ends of the bumper where I would only have plastic to deal with. No steel at the ends correct?
Sounds like that would work and a good idea too. There nothing but air inside. Make sure you have some kind of a drain hole.
Fyi: I mounted a Berkley turn and lock 4 rod holder inside for security. The top mounted to soundbar and the bottom zip tided to the bar roll bar.
Post pics when your done.
I have a lod front bumper with hoop (not stinger( im looking for cheap steel 10' rod around 1.5-2" ID) then weld them to the hoop with a bit of a rake on them. Soon as i get it all done ill post pics.
