Is this right? $400 for service?
Old 06-24-2008 | 01:31 PM
scouter4life's Avatar
Originally Posted by N2rock
Its in the "smaller manual"- the one that includes service schedules and warranty info. And there are 2 sets of service schedules- one set for "normal" which has all the oil changes at 6000 miles, and one set for "extreme" which has everything in 3000 mile increments.
I'll run out and check that and post what it says, but still shouldn't be much more than what I posted, just more often.
Old 06-24-2008 | 01:43 PM
RedrockX's Avatar
Hell, i went in for an oil change... they said my diff fluid was contaminated, and my throttle body was dirty.... and my injectors were dirty... (how could they tell the injectors were dirty...?)
but anyway... since they had it up for the oil, i said screw it, just do it.
595$$$$$$$$$$$$$$
WTF...???
Old 06-24-2008 | 01:46 PM
Just pulled my Warranty book and even that has nothing for 15000 miles, might be different for '07's but at least for mine, I show nothing for 15000.
Old 06-24-2008 | 02:16 PM
Embalmer's Avatar
yeah the price was 609 here and included the axels... went to a drive in vavoline for the same work, 175.
Old 06-24-2008 | 02:24 PM
RedrockX's Avatar
what is involved in this "high pressure" injector cleaning...?
i had it done to my old dodge (way back when)... smoked a lot, ran like crap till all the stuff burned out...
Old 06-24-2008 | 03:00 PM
Must be.... I just pulled my book (I have an '07) here's what is listed for 15000 mile service
Change engine oil and engine oil filter
check the coolant level, hoses and clamps
inspect the exhaust system
inspect brake hoses
Clean and lubricate soft top zippers (if equipped)
drain & refill front & rear axle fluid
inspect transfer case fluid, add if necessary
inspect engine air cleaner filter, replace if necessary
Now this is all listed in the "severe" driving conditions. Under the "normal" conditions most of the extra stuff listed above doesn't show up until 30,000
All good stuff to check once a year at least, but certainly not worth $400. You can buy the required fluids & filters for around 50-60 and do it yourself, then have the satisfaction of doing it. If you're not comfortabel doing it, check with some other local owners or Jeep clubs, I'm sure someone would be more than willing to help you out for a couple Beers and lunch, still save you about $300 bucks.
Old 06-24-2008 | 05:20 PM
Jusaplaya's Avatar
Be careful at dealerships. They will stretch the truth to get extra work done. Especially if you let your wife or someone who doesn't know alot about cars. From now own I do all my work myself.
Old 06-24-2008 | 07:38 PM
pearl-drum-man's Avatar
Originally Posted by MFalcon
Is this required to maintain the warranty? If it is not I would either service things diff's myself or find a local shop I trust . I say that because I have one that I trust and is very reasonable. If the warranty required it I would shop my nearest dealers.
Just save all receipts for what you do or have done outside of the dealer, same as if you do your own oil changes.
Old 06-24-2008 | 08:20 PM
Northernmedic's Avatar
Is your dealership offering a happy ending with that?
