Review - Master Flow Tsunami Air Compressor
Old 09-11-2008 | 06:07 PM
Zee's Avatar
Zee
Default Review - Master Flow Tsunami Air Compressor
I recently bought a Q Industries Master Flow Tsunami MF 1050 on Ebay for ~$35 + Shipping, which to Canada after everything cost me about $75.
It comes with a 16 foot coil hose, enough to easily reach all 4 tires. The screw on chuck is easy to use.
Has a very convenient case.
My only complaint, the gauge is not accurate.
Easily hooks up to the battery and sits on the ground.
It took a hair over 3 minutes to inflate the Stock 32" Rubi tire from 20 PSI to 40 PSI... yes I had to deflate it.
Construction of the unit is very solid, it gets hot with use, but I could easily pull the chuck off after the single tire test. I suspect, after 4 tires it will be very hot. You would need to wear a glove to pull the chuck off the unit.
The unit is meant to be run no more than 30 minutes at a time, but because of the speed, I would think you will rarely if ever need more than 30 minutes to inflate 4 tires.
All in all, for the price, this is an excellent unit.
It can be found on Ebay (make sure you get the Tsunami, not the cheaper version), summit racing, and several other places. In the past, it has sold under the Superflow name as well.
Old 09-11-2008 | 07:29 PM
Roxster's Avatar
Good choice. I just bought one in the U.S. at Costco for about $40. Great unit overall. I'm in the process of modifying it to mount on board and will post a write up when I do, but it's a great unit out of the box if you're looking for a portable set-up.
Old 09-11-2008 | 07:55 PM
jwilson2598's Avatar
Those are great little compressors, I have one myself. On thing I and some other guys have had happen is the coupler will go bad. If you notice it's a non-standard type coupler and actually has an o-ring inside of it. Mine developed a leak in the or-ring, so I went to the hardware store and got a standard coupler, and adapters from 1/8 to 1/4 thread and put it on the compressor I also replaced the end on the hose with a standard fitting as well, so now it uses a standard coupler with no more leaks.
Old 09-12-2008 | 07:35 AM
jkkat's Avatar
These are rockin good little compressors.
Old 09-12-2008 | 11:08 AM
jwetzel's Avatar
I agree. I have one of these little babies. Fantastic compressor in a nice little package. However, the nozzle leaks unless I sit there holding it at a 90 degree angle from the surface of the tire. Pretty annoying. So I'm going to replace that.
Old 09-12-2008 | 11:17 AM
JK-Fire's Avatar
Doesn't sound like much of a duty cycle if it gets so hot you can't touch it. I guess it will get you out of the woods though.
