Relocating mirror??? Suggestions???
Old 04-03-2007 | 08:31 AM
crwood1's Avatar
Default Mirror removed and problem of holes solved
I got a 4" ABS rough finish flat plastic disk cut with 3M adhesive on one side...black ABS matches eveything else on the jeep...several shots...
ID:	1145   Click image for larger version
ID:	1146   Click image for larger version
Old 04-03-2007 | 03:45 PM
W3CSX's Avatar
Here is what I have been working on this afternoon. Total cost about $27.00. The mirrors I picked up at Advanced Auto for $10 each. From Home Depot: two “T” brackets, a can of Rust-oleum and some rubber backing material to protect the paint.
I like the way there recessed, so there not sticking out any further than the flares. It almost looks like it should be stock. This is just a test fit. They have to be disassembled to paint the brackets.
Old 04-04-2007 | 06:20 AM
smack2020's Avatar
Nice, was the mirror already black? Does the mirror vibrate?
Old 04-04-2007 | 07:03 AM
HappyCurmudgeon's Avatar
Eternal ***erator
Wow, this is like that scene from Jurassic Park...
Looks Like Paparazzi Park... How fast was this guy running?!?!???
Old 04-04-2007 | 07:13 AM
doojer's Avatar
Originally Posted by W3CSX
Looks nice. Can you see the passenger side mirror fine from the driver's seat?
Old 04-04-2007 | 08:14 PM
W3CSX's Avatar
Thanks all
The mirrors came black. There also available in chrome if you want the bling. There made by a company called K Source. Part number RH083B. The view from the passenger side isn't the best. But, it's better than nothing. You can see enough to safely change lanes. I thought it was better to keep them uniform. If nothing else it will keep the law off your @$#.
Old 04-07-2007 | 09:00 PM
The_Superhoo's Avatar
can you close the door with those/what happens with the bracket spot when u put the doors back on?
looks good
Old 04-07-2007 | 09:15 PM
W3CSX's Avatar
I designed these for running with the doors off only. They get removed when the doors are replaced. Only two extra screws on each side, quick and easy.
Not to hijack but, I see you are in Charlottesville. Sunday the 22nd a few friends and I are going wheeling in George Washington NF. Want to join in?
Old 04-07-2007 | 09:25 PM
aww mannn dont tempt me haha
i've got my last week of class ever that week, including my big thesis paper :-(
thanks for the invite tho man, if it werent for that i'd likely take you up on it, since my JK would be here then :-(
back to topic! haha what happens with the holes when u put the doors back on? do the screws go back in them, and if so, they dont get in the way at all?
Old 04-07-2007 | 09:32 PM
W3CSX's Avatar
I didn't drill the holes to mount them. The mirrors are bolted using the upper bolts for the windshield brace. And yes I use the same screws to hold the mirrors on.
