relationship between MPG and Gear Ratio
X2, running 285's with tons of extra weight (see signature) and I just refilled and was at 19 mpg's. This is a daily driver with mix of stop and go and freeway. During the summer I'll usually get over 20 mpg's. It's all about the skinny pedal, these are not speed machines, no reason to shoot off the line.
can barely reach 15mpg. Your JK must be a miracle!
![crazyeyes](https://www.jk-forum.com/forums/images/smilies/crazyeyes.gif)
I've done a lot of long trips on I-75 too. No matter what vehicle I can set the cruise at 70 and get the newer (2008) EPA highway number. Now a head wind or driving faster than 70 will sink it. I drove with my younger brother recently. I'd call him compeletly typical. GAS-BRAKE-GAS. What about coasting?? I'm doing less than 60 every my vehicle enters the off ramp, yet the person behind me still has their cruise on 75 yet we will both be stopping at that big red light ahead. If you can ever spend some time in a car that gives instant mpgs like many GM or BMW's it will make you a lot thriftier on the gas pedal.
A JK getting 20 mpg isn't a huge deal. I have the stock 32 inch tires with 3.21 gear ratio and the 6-speed and periodically get hand calculated 22+ mpg on the highway (even on winter gas). I have an unlimited so my gas tank is about 21.5 gallons but if I do mostly highway driving I usually get over 400 miles per tank, even on winter gas.
![beer](https://www.jk-forum.com/forums/images/smilies/beermug.gif)
Hey tpm,
I'm thinking of ordering my JKU with 3.21's and the six speed. How often do you have to shift out of 6th on the highway? I usually cruise at 70 and I'm hoping it would hold the top gear. I'm waiting on the pentastar but I'm thinking they will be close in power at 2000 rpms.
As for what I get, I just filled up earlier today. I reset the mileage at every fill up and calculate the mpg's. The fill up earlier today was right at 16 gallons and I had done 310 miles, math works out to 19.375 miles per gallon. That's with doors and windows on and winter blend gas. Doors off and windows off with summer blend I get 1-2 mpg's better.
Hey tpm,
I will say it will depend more on you than the JK in a way whether you like 3.21 gears. Many people on this forum want JKs get get up and go fast. For them they need the higher gear ratio to get better acceleration. I personally bought my JK to get good fuel economy at the same time as driving slow with the top down, music up, and the option of going 1 mph off-road (where once 4-low is engaged you are good to go as far as you would ever want to take a stock JKU) which is why the 3.21s work for me.
Keep in mind that if you go with 3.21 you will notice it when you go to wheel off road. That's why the Rubi come stock with 4.10 and some models have a 4.10 option.
Thanks for the good info. Are you running 30 or 32 inch tires? I would love some 3.55's like my XJ had. I'm only getting 18 mpg's babying my Rainier right now so I am hoping on getting 21ish out of the pentastar.
I have the stock 32 inch tires (255/75R17 size to be exact).
