Recovery
Old 12-19-2009, 04:19 PM
Tebo's Avatar
Default Recovery
I'm just wondering if anyone could shed some light on where the best place to hook onto a car would be if trying to help them get unstuck or out of a ditch. 4x4's usually have some pretty obvious hook up points but if i was to come across a sedan in the ditch where should i hook up?
Old 12-19-2009, 04:26 PM
backwoodjk's Avatar
It depends on the car, stay away from the plastic bumpers!
http://video.google.com/videoplay?do...7228666255132#
This video will show you why!
Old 12-19-2009, 04:43 PM
Yoda's Avatar
LOL
Seriously. It's not easy. I tried to pull a toyota Yaris last year. We never found a spot to put the hook...
Old 12-19-2009, 05:23 PM
horwitzs's Avatar
Easy.
Let them hook up their end. That way you aren't responsible for any damage.
Here is another good example:
http://www.youtube.com/watch?v=uQTd_xXpDQ0
Old 12-19-2009, 05:52 PM
JK Dawg's Avatar
Many cars have a small hook or metal loop under the bumper. I believe that these were installed as tie down points during transit.
Old 12-19-2009, 05:58 PM
GoodysGotaCuda's Avatar
as mentioned, every one is different. Primarily cars these days have pull points made to get them on the tow truck from a straight flat pull..which sucks! Sometimes there is no way around damage, thats what happens!
Old 12-19-2009, 06:10 PM
mkjeep's Avatar
Check with local PD on recovering vehicles aswell. Around here they like to have an officer flagging traffic at least.
Old 12-19-2009, 06:17 PM
Former Vendor
tgrt's Avatar
You'd be surprised. I've pulled out more than one so called 4x4 that didn't have a tow point. I remember one guy I pulled out used his leaf spring. That's probably not a good idea, but he was desperate and willing to pay for the strap if it was damaged in any way. Which it was and he did. I always make the person hook the strap up to their vehicle.
Old 12-19-2009, 06:46 PM
tj-tigger's Avatar
I was surprised to find a metal loop under a car I helped out of a snow bank the other day. A younger kid lost control and slid into a snow bank on a corner. I only had a d-ring and a recovery strap. I hooked the d-ring to the loop under the car and then the strap to my jeep. I wasn't pulling too much weight as we wasn't stuck too bad. But it pulled him out just fine.
Old 12-19-2009, 07:13 PM
Bennyhana's Avatar
Check out what they call a "transit cluster" it fit's in the little holes in the frame or unibody. they work pretty sweet on vehicles that don't have recovory points if you can find a spot to put them. Although they are not for use with a dynamic recovery ie: snatch strap and a tug. Work fine with winching.
Quick Reply: Recovery
