rear axle ratio on 2012s?
I currently have 2008 Wrangler X auto (3.21 rear axle ratio). I have a 2012 Sport on order and I'm considering switching to a Rubicon. Does the 4.10 rear axle literally require the engine to rev 28% (4.10 divided by 3.21 equals 1.277) faster at highway speeds? [And, the 3.73 ratio would be 16% higher than the 3.21 using the same logic.] That would seem substantially "busier" than I'm used to. Also, any thoughts on the new 5-speed auto - is 5th going to be something of a super overdrive to help mileage?
So if 5th gear in the new auto is a similar ratio to 4th gear in the current auto (which I would assume it would be) then the engine speed will either be no different in OD and 3.73 gear ratios (compared to your RPM with 3.21 gears and 6th gear in your current JK) or only ~ 10% higher in OD if you get the 4.10 gears in the new 5-speed.
Hope this helps!
