Rain Guards/Wind Deflectors
I love these things.
Personal experience. I like the look of the in channel but they can cause issues if you have electric windows. (Binding issues and shorten the life of the motor) I use the tape on and if they come loose (usually around 3 years in my case) I clean them off and apply fresh 3M tape.Attachment 133515
Eternal ***erator
Mopar tape version
would definetly buy again. however, keep in mind they will interfere a little with removing the doors if you set the top sill on your shoulder for carry like some do. you wont be able to do that.
i dont find it to be an issue though.
I have the tape on also, Love being able to always have a window open.
It does create a caution when removing doors,
If you hang them on hooks on a wall, you can't do this anymore.
If you lean them against each other on the floor, be careful. space the bottoms out further.
Like the previous poster said, carrying them with your shoulder through the window is a no,no.
Once you realize these, your good to go.
Tape ones on the new JK.. 4 months old.. Love them.. Had them on the CJ for about 7 years before the started to flap. Super easy fix, heat them up, pull off, new tape 4 bucks. AVS
I like mine, I have the I side the channel type and have had no problems. I did not want the ones that tape onto the exposed portion of the door frame. Here are a few pics.
