Question about my 4x4
Old 11-07-2009, 10:40 AM
mkjeep's Avatar
Uhh, what kinda jeep we talkin about, this maybe?
If not,you shoulda drug that all over.
Old 11-07-2009, 12:32 PM
mannydefla's Avatar
Attachment 32534
Yep same like that
Old 11-07-2009, 12:45 PM
sin52's Avatar
Should tow that pretty easy. smear crisco all over your grass. that'll make it easier to slide. don't put it where your jeep is parked though.
Old 11-07-2009, 06:14 PM
daggo66's Avatar
How did it get to it's present location?
Old 11-08-2009, 02:57 AM
Mark Doiron's Avatar
Originally Posted by mannydefla
i was dragging yes ...
Originally Posted by sin52
... smear crisco all over your grass. that'll make it easier to slide ...
Well, dragging means that you have to be concerned with the coefficient of friction--which I imagine for that boat's canvas fabric is pretty high. You can reduce the coefficient of friction by, as Sin52 says, lubricating the grass. Once you get it moving, it should be much easier to keep it moving (both because of inertia, and because there'll now be lubricate stuck on the boat), so you may just need to lubricate a few feet out in front of the boat.
Old 11-08-2009, 03:50 AM
sin52's Avatar
I'm buying stock in crisco. Man that sucker should drag no problem once it gets moving.
Old 11-08-2009, 06:32 AM
Blackbeard's Avatar
X2!!!
Just curious, but are you trying to pull it from the Bow (Front), Stern (Back), or Sideways?
Is the Prop/Motor digging into the ground, acting like an Anchor?
Best of Luck!
Cheers!
BB
Old 11-08-2009, 06:43 AM
LaxAHolic's Avatar
Old 11-08-2009, 10:24 AM
benny's Avatar
i was dragging yes . trying to move it to a different spot that's it.. not a mile or any like that
maybe i was clutching to much.. hope was that .. disspointed
Should not be clutching at all,......that is probably your problem. If you ever feel the need to push on the clutch, all the way in quickly or all the way out, never ride the clutch.
Old 11-08-2009, 12:33 PM
sin52's Avatar
I was joking about the crisco too.
Quick Reply: Question about my 4x4
