Question about my 4x4
Old 11-07-2009, 08:44 AM
mannydefla's Avatar
Default Question about my 4x4
Hey everyone what is max I could pull with my jeep I tried to moved my little boat inside my backyard and the jeep with 4x4 on can't do it and
started to smell clutch
Old 11-07-2009, 08:49 AM
stlfan06's Avatar
Not enough info in your post to determine the problem.
Put it in 4LO and you shouldn't have to touch your clutch.
Old 11-07-2009, 08:50 AM
nthinuf's Avatar
Depends on what you have. (2 or 4 door, transmission, gears, tow package)
Could be:
1000
2000
3500
Go to the jeep website and look in the 'For Owners' - Towing Capacity section...
Old 11-07-2009, 08:54 AM
duneslider's Avatar
What do you consider a "little boat"? The jeep is only "rated" to tow 3500 for the unlimited. Why did you think you needed 4wd? I have pulled my little utility trailer loaded with 4000lbs around the yard with no issues. No need to use 4wd unless you are spinning the tires.
Old 11-07-2009, 09:09 AM
mannydefla's Avatar
Rear
dana 44
3.21 axle ratio
front
dana 30
its a 4 door unlimited 4x4
i tried with 2x4 first wasn't moving then tires were spining . its a little boat. some how the fucker is heavy . so i put the 4x4L and kinda started moving and i picked up the clutch smell ..tried again and same shit.. so not sure what's happening .
here is a pic of the "boat" dont laugh
me and a friend tried moving it by hand but couldn't move it a bit
not sure how heavy this is
Old 11-07-2009, 09:26 AM
Mark Doiron's Avatar
Originally Posted by mannydefla
... its a little boat. some how [it's] heavy ...
Okay, this is probably a stupid question, but did you have it on a trailer?
The tow rating is for trailers--the kind with wheels--not for dragging.
Old 11-07-2009, 09:27 AM
Suffolk JK's Avatar
Do you have larger tires? If you are in 4L, you don't need the clutch. Once you release it, the tires will start turning and look for traction, especially since you're on grass. You can fully release the clutch and ONLY press the accelerator pedal.
Old 11-07-2009, 09:39 AM
jlcolon2001's Avatar
Rear
dana 44
3.21 axle ratio
front
dana 30
You can borrow my niece's Jeep!!
Sorry!
I couldn't resist!
Old 11-07-2009, 09:48 AM
mannydefla's Avatar
i was dragging yes . trying to move it to a different spot that's it.. not a mile or any like that
maybe i was clutching to much.. hope was that .. disspointed
Old 11-07-2009, 09:51 AM
mannydefla's Avatar
Yes, I just have one but am using in my jet ski maybe you right I need buy one for that
Quick Reply: Question about my 4x4
